Light Studio Terminal 1.xx
all LED control software
LS Terminal, iqLED tracer, Jinx!, Adobe after effects, LED Edit and others
Post by Magic Friend » 02 Feb 2019, 18:26
This software is designed to convert video animations into offline content, for playback via smart pixels. As a result of the conversion, we get one or a group of executable files with the *.led extension. You have 256 ports available, each 2048 pixels maximum. A pixel trace has an arbitrary trajectory: Line, matrix, triangle, zigzag, square, freehand outline and more. This software is not tied to any type of LED IC chip. For specific IC chip support, please refer to the iqLED (RF) controllers specifications.
Minimum System Requirements
OS: Windows XP / Windows 7 / Windows 8 / Windows 10 / (64-Bit or 32-Bit)
CPU: Intel Core 2 Duo E8200 2.66 GHZ / AMD Phenom X3 8750 2.4 GHZ or better
RAM: 4 GB
HDD: 100 MB free HD space
Video: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better
!!! THIS IS A FREE SOFTWARE WITH FULL FUNCTIONALITY !!!
Download and enjoy...
Example 1 - A group of animated real pixel costumes.
Example 2 - Simplified pixel model of a group of costumes
Example 3 - pixel Matrix model
Example 4 - Real video of fire reproduction on WS2812B matrix
Example 5 - A group of animated real pixel suits with music radio synchronization
This software is designed to convert video animations to smart pixels. As a result of the conversion we get one or a group of executable files with the extension *.led (content for iqled controller).
The Light Studio Terminal 1.xx software prepares content for playback on the following devices:
-iqLED-Alpha-A1-RF Module (Active);
Link: https://aliexpress.ru/item/1005005974249417.html
-iqLED MS OD8K (Active);
Link: viewtopic.php?f=4&t=4012
-iqLED Alpha-B8 RF L2 (Active);
Link: viewtopic.php?f=4&t=4016
-iqLED Alpha-B1 RF L2 (Active);
Link: viewtopic.php?f=4&t=3997
-iqLED Alpha-B1 L1 (Active);
Link: viewtopic.php?f=4&t=3982
-iqLED-Alpha-A2-RF (Products of 2025);
-iqLED-Alpha-A5-RF (Products of 2025);
-iqLED-Alpha-C8-RF (Products of 2024);
-iqLED-Alpha-A3-RF Module (Products of 2024);
-iqLED-Alpha-A1-RF Module (Products of 2023);
-iqLED Alpha-B8-RF (Products of 2022);
-iqLED Alpha-B1-RF (Products of 2022);
-iqLED POI F4 classic Mode (Products of 2019);
-iqLED RS, iqLED RF 1.4, iqLED RF x8S (Products of 2019);
-iqLED RF v1.1,iqLED RF 1.2(MOD) (Products of 2018);
-Led Master mini RF 5.2, Led Master mini RF 5.4, Led Master mini RF 6.1 (Products of 2017);
-Led Master mini v3, Led Master mini RF v4 (Products of 2017);
-Led Master mini v2 (Products of 2016).
Various smart pixels can be supported: WS2811, WS2812, WS2812B, WS2813, WS2815, WS2818, UCS1903, SK9822, APA102, GS8206/GS8208 and many more.
RESOURCES
Below are links to resources. If your archive does not open or an error occurs, please use the new version of WinRAR.
Release:
23/10/2023 ver. 1.61
Download Soft "LS Terminal" x64:
https://iqled.org/soft/LS-Terminal-1.61x64.rar
17/10/2023 ver. 1.60
https://iqled.org/soft/LS-Terminal-1.60x64.rar
16/05/2021 ver. 1.59
https://iqled.org/soft/LS-Terminal-1.59x64.rar
Download Soft "LS Terminal" x32:
https://iqled.org/soft/LS-Terminal-1.59x32.rar
05/04/2021 ver. 1.54
https://iqled.org/soft/LS-Terminal-1.54x64.rar
https://iqled.org/soft/LS-Terminal-1.54x32.rar
13/01/2019 ver. 1.51
https://iqled.org/soft/LS-Terminal-1.51x64.rar
https://iqled.org/soft/LS-Terminal-1.51x32.rar
Light Studio Terminal 1.xx software can easily play and convert animations from Jinx! software.
It is Jinx! that we recommend as a very simple software for a quick start. 15-30 minutes to master the software.
Below is a link to the Light Studio Terminal 1.xx user manual. Use the auto-translator in your browser.
viewtopic.php?f=36&t=3649
mamfred
Re: Light Studio Terminal 1.xx
Post by mamfred » 07 Feb 2020, 22:36
hi, where i can find the Ls terminal user manual??
thanks
mamfred
Post by Magic Friend » 07 Feb 2020, 22:48
mamfred wrote: ↑
07 Feb 2020, 22:36
thanks
mamfred
Hello, regret it is currently not the text manual, but we are working on its creation.
This video will help you.
mamfred
Post by mamfred » 08 Feb 2020, 14:27
thanks for replay, im wondering if there any way to export the led layout to a dxf file or image file or any other way, so i can cut on my cnc machine the exact location of led buld for a irrerrular matrix, i build channel letter sign so i need to cut the board on cnc and place the exact location of each 12mm led bulb ,
this is one my first questions before i can order some boards to text, i still looking your youtube channel to get all idea, and see how to implement on my small signs shop here in chile
thanks for your time , have a great day
mamfred
Post by Magic Friend » 08 Feb 2020, 22:27
mamfred wrote: ↑
08 Feb 2020, 14:27
mamfred
You can first prepare a stencil for the pixel map of your project (PNG file), then in our software iqLED tracer you can perform pixel markup.
CiscoTek
Post by CiscoTek » 08 Mar 2025, 23:26
Hello! У меня новый компьютер с win11. Раньше я использовал win10. С LS terminal все в порядке на старом ПК, вместо нового я не могу открыть ни один проект, потому что он говорит мне "файл доступа к ошибке" (ERROR ACCESS FILE). Это случилось с вами?
Файлы не зашифрованы. У меня есть другой компьютер с Windows 10, и он выдает ту же ошибку. у меня есть как минимум 150 проектов, я не могу воссоздать их снова.
