2 Hub 8 on 1 RF 1.4?
questions about different LED controllers
Led Master mini, iqLED RF, other SD controllers for Smart pixels
RebelJef
Post by RebelJef » 28 Aug 2019, 08:50
Hi, Is it possible to connect 2 hubs to 1 RF 1.4 controller. I need to control 13 different led groups on 1 costume?
Re: 2 Hub 8 on 1 RF 1.4?
Post by Magic Friend » 28 Aug 2019, 20:26
RebelJef wrote: ↑
28 Aug 2019, 08:50
Hi, do you already have a hub and controller iqLed RF 1.4, or are you just planning?
RebelJef
Post by RebelJef » 30 Aug 2019, 10:06
Yes I have 2 RF1.4 and 2 HUBS*8
RebelJef
Post by RebelJef » 30 Aug 2019, 10:11
Yes I do, 2 RF 1.4 and 2 HUBx8
Post by Magic Friend » 31 Aug 2019, 20:13
RebelJef wrote: ↑
30 Aug 2019, 10:11
Hi, you need one controller to control one hub. It is not possible to connect 2 hubs to one controller.
Maybe you are interested in our new product, the controller iqLED RFx8S, it's controller integrated with the hub. A total of 8 ports can be controlled by 8x1024 pixels.
iqLED RFx8S
RebelJef
Post by RebelJef » 03 Sep 2019, 11:19
Hi, thanks for the info but I've now those controllers and hubs to work with. I'll set up both RF's with the Hubs to create my costume which will consist of :
1. 2 Shoulder pats
2. 2 Upper arm
3. 2 Lower Arm
4. 2 Upper Leg
5. 2 Lower Leg
6. 1 Front Body
7. 1 Back Body
8. 1 Face
So 13 separately connections and 4-6 attached DMX controllers for my side glow fiber optics. Still working on the design.
Maybe in later versions you could integrate a WiFi connection. 433 <> WiFi Bridge?
Might take a while, still need some parts. Once completed I'll share the final design with the forum.
Jef
Post by Magic Friend » 12 Sep 2019, 20:17
RebelJef wrote: ↑
03 Sep 2019, 11:19
Hi, for what reason? Wi-fi is a source of instability at large events. It is good only at home.
If you have any difficulties with the hub, please contact, I will help you.
