2 Hub 8 on 1 RF 1.4?
Hi, Is it possible to connect 2 hubs to 1 RF 1.4 controller. I need to control 13 different led groups on 1 costume?
Re: 2 Hub 8 on 1 RF 1.4?
Yes I have 2 RF1.4 and 2 HUBS*8
Yes I do, 2 RF 1.4 and 2 HUBx8
Hi, you need one controller to control one hub. It is not possible to connect 2 hubs to one controller.
Maybe you are interested in our new product, the controller iqLED RFx8S, it's controller integrated with the hub. A total of 8 ports can be controlled by 8x1024 pixels.
iqLED RFx8S
Hi, thanks for the info but I've now those controllers and hubs to work with. I'll set up both RF's with the Hubs to create my costume which will consist of :
1. 2 Shoulder pats
2. 2 Upper arm
3. 2 Lower Arm
4. 2 Upper Leg
5. 2 Lower Leg
6. 1 Front Body
7. 1 Back Body
8. 1 Face
So 13 separately connections and 4-6 attached DMX controllers for my side glow fiber optics. Still working on the design.
Maybe in later versions you could integrate a WiFi connection. 433 <> WiFi Bridge?
Might take a while, still need some parts. Once completed I'll share the final design with the forum.
Jef
1. 2 Shoulder pats
2. 2 Upper arm
3. 2 Lower Arm
4. 2 Upper Leg
5. 2 Lower Leg
6. 1 Front Body
7. 1 Back Body
8. 1 Face
Jef
Hi, for what reason? Wi-fi is a source of instability at large events. It is good only at home.
If you have any difficulties with the hub, please contact, I will help you.
